2005 Mazda MPV diagnostic codes
LUMPY46JE
Engine Performance problem
2005 Mazda MPV 6 cyl Two Wheel Drive 92,000 miles
I'm getting p0134 (O2 sensor CKT No activity Bank 1 sensor 1) and P0154 (O2 sensor CKT No activity Bank 2 sensor 1). I've replaced the Upstream O2 sensor and I'm still getting the same 2 codes. Before I replace the Downstream sensor I want to make sure if I'm headed in the right direction
Feb 27, 2010 at 9:27 AM
  • 31,937 POSTS
Hi there,
I would be doing a circuit continuity test from the up stream sensor to the ECU and if this is a heated O2 sensor check that circuit as well, start here.
Mark (mhpautos)
Feb 27, 2010 at 10:15 AM
