2004 Mazda MPV Power Windows
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRACYKIELMAN
I rolled my window down this morning and it would not go back up. It is only the driver's side window. All other windows are fine. We replaced a fuse for the windows last week due to the fact that none of them worked at the time. After replacing the fuse they were fine until now but it is only one window this time. I do not here anything running when I try to use the control for the window. The controls for the other windows work including the ones on the driver's side door panel. Any suggestions?
Mar 17, 2010 at 1:45 AM
DAVE H
  • 13,383 POSTS
check/replace the window motor/regulator .. check/replace the switch
Mar 17, 2010 at 3:58 AM
