EGR Valve Removal & Replacement
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
T.C. BURNS
How can I get access to the EGR tube attachment on the side of the EGR valve and loosen the nut holding the tube on the side of the valve body. There appears to be no way to get a wrench on this tube nut. Would it be better to remove the entire EGR valve with the tube intact in order to get access to the tube nut? I am changing the EGR valve due to a check engine code and rough running that has been traced back to the EGR valve. Thanks to Mazda, the entire valve must be replaced since they do not service the solenoid. The tube nut on the back side of the valve body is almost impossible to access.
Feb 28, 2008 at 7:26 AM
MASTERTECHTIM
  • 4,750 POSTS
You must use a crows foot which is a small wrench end with a extension that can be plugged in.
Cheers
Feb 28, 2008 at 9:00 AM
T.C. BURNS
Thanks worked perfect!
Feb 28, 2008 at 9:24 AM
MASTERTECHTIM
  • 4,750 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Feb 28, 2008 at 9:28 AM
