Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
MPV
Engine
Oxygen Sensor
Replace/Remove
2001 Mazda MPV Oxygen Sensor at bank 1 sensor 1
2001 MAZDA MPV
85,000 MILES • 6 CYL • FWD • AUTOMATIC
THOMASK1040
MEMBER
1 POST
How do I identify the wire to connect the voltmeter?
How do I change the sensor at bank 1 sensor 1?
May 12, 2010 at 3:57 PM
BLUELIGHTNIN6
Experienced Mechanic
brown/yellow wire should be signal wire. just disconnect battery, disconnect oxygen sensor wire connector and unbolt from exhaust.
May 12, 2010 at 4:07 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
