egr valve
ANNIEMOE
Engine Performance problem 6 cyl Front Wheel Drive Automatic 105000 miles
how hard it is to change this valve?
Jul 11, 2010 at 10:40 AM
  • 55,691 POSTS
Here is a test video to see if the valve is bad once you get it off.
https://youtu.be/DqUCbbKdWf4
EGR VALVE REMOVAL/INSTALLATION
1.Disconnect the negative battery cable.
2.Remove the air cleaner.
3.Disconnect the vacuum hose.
4.Disconnect the EGR pipe.
5.Remove in the order indicated below.
1.EGR valve connector
2.EGR pipe
3.EGR valve
6.Install in the reverse order of removal.
7.Connect the negative battery cable.
Check out the diagrams (Below)
Cheers, Ken
Feb 13, 2018 at 5:28 AM
