Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
SPONSORED LINKS
Saturday, June 12th, 2010 AT 5:19 PM
