2000 Mazda MPV I have the error codes but cant find how to
MELLULA1015
  • 2000 MAZDA MPV
  • 6 CYL
  • FWD
  • 120,000 MILES
I went to checker and got the error codes for my check engine light and the following two codes were on it P0136 and P1512. I know one is a oxygen sensor, the other I found out it had something to do with a manifold stuck shut, but I don't know where or if it is a repair I can do. I also did find out my transmission is shot too. If that helps at all. With the combination of these two codes, what needs to be done? Thank you for taking the time to help me.
Saturday, July 12th, 2008 AT 1:03 AM
KHLOW2008
  • 41,814 POSTS
Hi mellula1015,
Check the P1512 first, it can cause the O2 sensor to malfunction.
I am not sure of the location but one of the vacumn valves should not be working properly. Check for clogged or dislodged vacumn hoses and faulty solenoids.
Sunday, July 13th, 2008 AT 10:59 AM
