2000 Mazda MPV Grinding brakes
12,200 MILES • 6 CYL • FWD • AUTOMATIC
DAN CARTER
My brakes (or something down there) grind when I brake - but only when moving forward - not in reverse. It is not a constant grind, but on-off-on-off as tho' the pads have a high spot. I replaced pads and rotors w/ quality parts. I believe calipers are working properly (because not constant grind, nor in when reveres). My thought is wheel bearings and/or CV joints?? Any suggestions?? Thank you.
Oct 1, 2008 at 4:10 AM
KHLOW2008
  • 41,812 POSTS
Hi Dan,
Thank you for the donation.
It should not be from the CV joints or wheel bearings. I would suggest checking the rotors for any uneveness or dents.
Check if the backing/cooling plates are too near the rotors.
Oct 1, 2008 at 6:33 AM
