2000 Mazda MPV fuel pressure
165,000 MILES • 6 CYL • FWD • AUTOMATIC
EJ71
lacks power installed fuel pressure gauge pressure varies from 60 psi to 20 psi under load needle on fuel gauge just keeps jumping around have already changed fuel pump same thing
Mar 19, 2010 at 2:59 PM
  • 75,988 POSTS
Fuel System Pressure Fuel line pressure 0.38-0.42 mpa (55-61 psi)
Fuel hold pressure 0.176 mpa (25.5 psi)
Check and test the fuel pressure regulator, fuel pressure control solenoid and fuel pressure pulsation damper-
Mar 19, 2010 at 3:15 PM
