2000 Mazda MPV Engine Missing
171,000 MILES • 6 CYL • FWD • AUTOMATIC
SHAWMERRILL
My MPV seems to be slightly missing every once in a while when I am in drive either moving or idling. It is almost like it quits for a split second then continues. What could be causing this issue?
Feb 26, 2010 at 7:34 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 26, 2010 at 10:04 AM
