How to replace the water pump
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIZZEZBURNZ
my van started overheating and the battery went dead which is probably 2 seperate issues but need to fix the overheating first... it overheated, I checked cooling levels, seen small drip. checked hoses, no leak. radiator is new, thermostat is new. (new is 4 months old) when we finally were able to determine leak it appeared to be coming out of engine. at bottom where I would guess the water pump is. does this sound like water pump and can I find out without having to pay a mechanic because Im broke...also if you could give me a good idea on how to chane the water pump on this engine becasue it is foreign to me. Any help please..thank you
Aug 4, 2010 at 9:51 AM
  • 75,988 POSTS
REMOVAL / INSTALLATION Disconnect the negative battery cable. Turn the crankshaft so that the No.1 cylinder is at TDC of compression. Drain the engine coolant. Remove the timing belt.
https://images.2carpros.com/forum/automotive_pictures/12900_w1_10.jpg
Remove in the order indicated in the table. Install in the reverse order of removal. Start the engine and inspect for coolant leakage.
Aug 4, 2010 at 10:33 PM
RONH2009
i changed the water pump on my mpv and now my van wont start what could have happend
Aug 19, 2019 at 12:06 PM (Merged)
  • 31,937 POSTS
Hi there,
Just start with re checking any electrical connections that you you undid, and get a scan done as well, it should not be very much.
Mark (mhpautos)
RONH2009
[quote:4702733de8="mhpautos"]Hi there,
Mark (mhpautos)[/quote:4702733de8] ok i will check ..also i just found out that it call for the timing belt to be removed wich i did not know at the time why would i have to do this if it has nothing to do with the pump if so could it be out of time
  • 31,937 POSTS
Hi there ,
I don't have access to the data base just now, is this a cam belt driven pump? If so the valve timing may be out.
Mark (mhpautos)
