1998 Mazda MPV removal of the alternator
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGKATT
how do i remove the alternator from the 98 mazda mpv do you have a diagram
Oct 16, 2010 at 4:11 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1998_mpv_alternator_1.jpg
Removal and Installation WARNING: * When the battery cables are connected, touching the vehicle body with generator terminal B will generate sparks. This can cause personal injury, fire, and damage to the electrical components. Always disconnect the battery before performing the following operation. 1. Disconnect the negative battery cable. 2. Remove in the order indicated in the table. 3. Install in the reverse order of removal. There you go.
Oct 16, 2010 at 4:20 AM
