1998 Mazda MPV Catalytic Converter
1998 MAZDA MPV
109,000 MILES • 6 CYL • 4WD • AUTOMATIC
BMACHOLD
Hello. My check engine light is on in my 98 Mazda MPV. I had the codes pulled at Autozone and it indicates a problem with the catalytic converter. How long can I drive it before getting this fixed? Will I be causing damage to the engine by continuing to drive it until I can afford to have it fixed? Is this an expensive repair? Thank you.
Mar 17, 2009 at 5:13 PM
What you need to do is find out why the catalytic converter went bad before you replace it, the replacement is not gonna do you good.
Mar 17, 2009 at 9:55 PM
MAZDAMPV1998
Hey bmachold,
Did you find the solution to your problem? I have the same problem and not sure how long can I wait before getting it replaced.
Thanks,
Ajay
Apr 8, 2009 at 8:04 AM
