1997 Mazda MPV SYSTEM NOT READY
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
METER01
THANK YOU FOR READING THIS EMAIL.I HAVE HAD 5 INSPECTIONS FOR THIS VAN.ALL OF WHICH SAYS "SYSTEM NOT READY".THE FIRST TEST SAID REPLACE OXY.SENSOR..I DID.CHECK ENG. LIGHT WENT OFF AND THEN I DROVE HUNDREDS OF MILES.
STILL SAYS SYSTEM NOT READY.I JUST BOUGHT THIS 2 MONTHS AGO AND NOW IM STUCK WITH IT.IT RUNS FINE AND PERFORMS WELL.CAN I GO TO A MAZDA DEALERSHIP AND HAVE THEM INPECT AND RESET COMPUTER FOR ME?OR IS THIS SOMETHING I CAN DO?THANKS FOR ANY TIPS OR SUGGESTIONS..
Oct 7, 2010 at 4:43 PM
KHLOW2008
  • 41,812 POSTS
Hi meter01,
Give this a try and see if it works.
GENERIC COMPUTER RELEARN PROCEDURES
Some manufacturers identify a specific relearn procedure which will help establish suitable driveability during relearn stage. These procedures are especially important if vehicle is equipped with and electronically controlled automatic transmission or transaxle. Always complete procedure before returning vehicle to customer. The following general procedures are to be used if driveability problems are encountered after power loss or battery has been disconnected. These procedures may provide an aid in eliminating these problems.
Automatic Transmission
• Set parking brake, start engine in "P" or "N" position. Warm-up vehicle to normal operating temperature or until cooling fan cycles.
• Allow vehicle to idle for one minute in "N" position. Select "D" and allow engine to idle for one minute.
• Accelerate at normal throttle position (20-50%) until vehicle shifts into top gear.
• Cruise at light to medium throttle.
• Decelerate to a stop, allowing vehicle to downshift, and use brakes normally.
• Process may be repeated as necessary.
© 2008 Mitchell Repair Information Co., LLC.
Oct 8, 2010 at 3:33 AM
