Engine Mechanical problem
1996 Mazda MPV 6 cyl Four Wheel Drive Automatic
Our MPV has a consistant oil leak. We have pressure washed the bottom of the motor, and it was clean for a couple of days. There appears to be oil all over the bottom side of the engine, as if it is blowing from some location. When you stop and let the vehicle sit,
the oil seems to run off and puddles up under the van. It will leave a spot of oil about 6" in diameter. We keep a check on the oil level, and add about 1 qt every couple of weeks. Need to some possible solutions.
Dec 13, 2009 at 1:04 PM
