white smoke from exhaust
1994 MAZDA MPV
INGASPLAY
  • 5 POSTS
Engine Cooling problem
1994 Mazda MPV 6 cyl Four Wheel Drive 155377 miles
Thinking to buy. Owner states that had a new water pump 3 years ago and thinks it was going again (didn't know if it would help) anyway said was driving and engine heated up a little and white smoke came out exhaust. Went and checked it out constant large amout of white smoke spurts out of exhaust on startup. No air bubbles from radiator, no milky or water in oil, but oil level is higher then thought possible! I know excessive oil can cause wite smoke but I am concerned about the statements made to me about the engine getting hot and thier worries about the water pump. but ... with oil level don't know if they even knew what they were talking about! Help what do think tooo much oil or head
Sep 27, 2009 at 9:34 AM
IMPALASS
  • 3,112 POSTS
Hello –
Is your model just the MPV or the LX and what is the engine size in liter?
Well, it sounds to me like a blown head gasket….the oil level is gaining due to the coolant. White out the tail pipe means water is being burnt in the cylinders.
To check the head gasket you can get a kit to pour in and check…..the AZ may have this. Here is the site to see it.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Sep 27, 2009 at 12:28 PM
INGASPLAY
  • 5 POSTS
OIL LEVEL IS WAY OVER WITH CAR SITTING FOR MONTHS NOT AFTER STARTUP
Sep 27, 2009 at 3:46 PM
IMPALASS
  • 3,112 POSTS
Hello –
Drain the oil and check to see if milky. Then refill to the proper quantity.
I would still check out the head gasket leak detector
Thank you very much for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
Sep 28, 2009 at 3:18 PM
