1994 Mazda MPV My Mazda MPV 1994 van was suddenly stopped w
1994 MAZDA MPV
INGASPLAY
  • 5 POSTS
Engine Performance problem
1994 Mazda MPV 6 cyl Automatic
My Mazda MPV 1995 van was suddenly stopped while driving. The engine turns over and sounds like its getting ready to start but it does not start. Please suggest what could the possible problem. I replaced the fuel filter and checked the mass air sensor and fuel filter and pressure regulator and pressure dampner all of which were not the problem. Also there was a strong fuel smell inside the van prior to this
Sep 20, 2010 at 11:32 AM
  • 31,937 POSTS
Hi here,
Thank you for the donation,
Check that the plugs are not fuel fouled, check for a good spark, if you have a good park, clean or replace plugs, if no spark run a diagnostic scan and check for any unresolved fault codes, post your findings her for more assistance if required.
mark (mhpautos)
Sep 20, 2010 at 11:30 PM
INGASPLAY
  • 5 POSTS
HAS SPARK????????????? CODE 16 EGR VALVE SHOWS UP COULD IT CAUSE CAR TO DIE LIKE THAT AND STILL SOUND LIKE TURNING OVER BUT WONT
Sep 22, 2010 at 8:13 AM
  • 31,937 POSTS
The EGR will not stop the engine from running, you will have to check that you have spark at the plugs, fuel pressure and injection pulse.
Mark (mhpautos)
Sep 23, 2010 at 1:01 AM
INGASPLAY
  • 5 POSTS
attached gauge pressure is fine has spark. before this strong odor of gas filled inside car
Sep 23, 2010 at 6:52 AM
MERLIN2021
  • 17,250 POSTS
An egr that is stuck open will prevent it from starting.
Also check for a broken gas line.
Sep 24, 2010 at 1:32 PM
