1994 Mazda MPV bypassing oxygen sensor
1994 MAZDA MPV
123,159 MILES • 6 CYL • 2WD • AUTOMATIC
STEBRA@VALUE.NET.NZ
I am in the process of fitting a hydrogen/oxygen gas cell producer to supplement the petrol vapour. I have been told that I need to "fool" the computer so that it will not ADD aditional petrol vapour when I am feeding the supplementary gas to the intake manifold. Can I simply put a manually adjustable potentiometer across the two wires that used to feed the computer from the oxygen sensor. Set it for "rich" when cold then set it "lean" when warmed up? I would then leave the oxygen sensor disconnected.
Thanks.
Apr 16, 2008 at 11:40 PM
GRYPHON101
You don't want to bypass your O2 sensor, but you're on the right track. Just adjust the volts sent from the O2 sensor, adjusting it less than 5 volts leans the fuel. I have seen where 'pots' alone do not work. I bought my 'adjuster' from ebay
Aug 15, 2008 at 12:29 AM
