1993 Mazda MPV corner lights
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
MENEO0483
hi i just change my passanger corner light and doesn't work i checked the fuses and they are ok what can i do?
thank you
Mar 13, 2008 at 10:27 AM
MASTERTECHTIM
  • 4,750 POSTS
you need to get a test light and put it across the 2 terminals and see if it lights. then you need to check for power and ground at plug and find out what you are missing. you are either going to have no power or no ground. get back to us and we will take it from there
Mar 13, 2008 at 10:45 AM
MENEO0483
don't you think that could be the relay?. just a question cause i tried everything but nothing
Mar 13, 2008 at 11:28 AM
MASTERTECHTIM
  • 4,750 POSTS
it could be a hundred things, thats why we need to certain tests to determine. i think more than anything its going to be a wiring problem or connection
Mar 13, 2008 at 12:10 PM
