1993 Mazda MPV Antilock and Brake lights on
ALAFOL
Brakes problem
1993 Mazda MPV 6 cyl
Just recently, the anti lock and brake lights have been on. The antilock lights go on at random times. I have to start braking much sooner as I approach the streetlights because sometimes the brakes don't hold. The brake pedal sometimes deflates to a lower level/height than normal . Does anybody know what I can do or what the problem is? Thanks.
Jul 8, 2008 at 11:07 AM
KHLOW2008
  • 41,812 POSTS
Hi alafol,
Check the brake fluid level, it should be low.
You need to check the master cylinder and the brake system for leaks.
Jul 12, 2008 at 8:20 PM
