1992 Mazda MPV Weak Heater
1992 MAZDA MPV
110 MILES • 6 CYL • 4WD • AUTOMATIC
SCOTT WEILER
I can't seem to get good heat out of my heater. I had a mechanic flush the core but it still doesn't work. Also, there is an passenger heater that doesn't seem to work either. The engine seems to be running at the correct temperature and I recently had the radiator replaced (the heat didn't work before either). If you turn the fan off for a few minutes, than put it back on, it blow reasonably hot air for a few seconds, then it cools back down. I am guessing that the heater core is partially blocked, but I was just hoping that there was another possibility since it is a big job to replace it.
Oct 22, 2008 at 4:13 AM
DOCFIXIT
  • 18,828 POSTS
You may have a blend door problem. Go from hot to cold on control couple times is there a diffenence in temp?
Oct 22, 2008 at 4:29 AM
TWOCYCLE
I'm having the same exact problem. Control panel adjustments all work on mine. New thermostat did'nt do the trick either. The cores have to be the root of the problem. Please reply if you solve the issue.
Nov 16, 2008 at 11:26 AM
