1992 Mazda MPV Fuel Problem
1992 MAZDA MPV
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
VVISHALLPPATELL
The car cranks however there is no ignition. The spark plugs and starter are good, however I believe there is no fuel getting to the engine. What is the best way to check the fuel pump and are there any other known causes that would result in this problem?
Can someone please explain how to properly remove the fuel pump?
Oct 19, 2010 at 2:50 AM
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 19, 2010 at 7:43 AM
