1991 Mazda MPV Fuel injection
1991 MAZDA MPV
TERRY P
  • 13 POSTS
Engine Performance problem
1991 Mazda MPV 4 cyl Two Wheel Drive 160000 miles
The engine lost power i am getting spark on all cylinders the engine has a dead miss the owner replaced all plugs wires cap rotor and the distributor I ran the engine what i found was #3 cylinder isn't getting any fuel the owner has ohm the injectors he tell me they all read the same can you tell me what I need to check next
May 15, 2010 at 1:05 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The injector can still be faulty even if it is powered up, listen for a click, place a long screwdriver on the injector and place you ear on the other end, you should heart the injector click when running.
mark (mhpautos)
May 15, 2010 at 2:24 AM
TERRY P
  • 13 POSTS
We tried a new injector still nothing I am going to try noid lights to see if ther is a signal at the injector if ther is not what do I try next? I am going to check again for spark with a spark checker
Jun 20, 2010 at 12:27 AM
  • 31,937 POSTS
do this and let me know what you find, i will have a think about alternatives in the meantime.
mark (mhpautos)
Jun 20, 2010 at 12:42 AM
TERRY P
  • 13 POSTS
Ok I put the noid lights and spark checker good spark no signal at the injector and I checked the noid light on another injector it checked good
Jun 20, 2010 at 6:20 AM
  • 31,937 POSTS
Check continuity of injector wire (light green / black) to term U2 at ECU and wire (black / yellow) to main relay.
Mark (mhpautos)
Jun 20, 2010 at 10:11 AM
