1991 Mazda MPV Car wont turn over.
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
SWERVE83
ok so, i changed the head gasket on my friends MPV van. all the connections are connected. all the grounds are grounded but for some reason it wont turn over. i think its the ignition relay but im not sure. is there any other reason why it wont turn over. i checked all the fuses and they are all fine. im lost one this one and need help please.
Jul 3, 2010 at 11:50 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I emailed you a wire diagram for your starter look's like a pretty easy circuit.Print up the diagram also do you have a test light or a multimeter?So we can trace power?Have you tested for constant power at the starter black and red wire and when you turn the key to the start position power at the S terminal of the starter solenoid black and red wire?
Jul 3, 2010 at 4:26 PM
