1990 Mazda MPV Dashboard lights go on
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEON1990
While the engine is on, when I press on the accelerator, whether the car is moving or not, the "charge'" "rear light," and the "Leveler" lights on the dashboard go on. When I step off the accelerator, the go off most of the time.
Jun 15, 2009 at 9:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe a faulty diode in alternator a scope test of alternator will show if restifier bridge is faulty. Check alternator voltage output with meter see if voltage is steady as RPM goes up.
Let me know
Thanks for donate
Jun 16, 2009 at 1:59 AM
LEON1990
The alternator output varies very little. It goes up from 17.8 V at idle to maybe 18.5 V at 3000 RPM.
I may have neglected to say that everthing other than the dashboard lights appears to be working.
Thanks
Jun 16, 2009 at 2:32 AM
DOCFIXIT
  • 18,828 POSTS
Alternator output out of range Mazda specs 14.7 to 15.5 at 3000. All the lights that come on have a diode in circuit to prevent current flow possible high out put has fried diodes. Allowing voltage to travel to lights.
Jun 16, 2009 at 2:52 AM
LEON1990
Thanks, i guess I'll have to go Mazda after all
Jun 16, 2009 at 4:01 AM
