1990 Mazda MPV Alternator
167,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAMPRESEA722
How to replace ALTERNATOR...
May 31, 2010 at 10:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Disconnect the wiring and label for easy installation.
Remove the mounting and adjusting bolts.
Remove the drive belts.
Remove the alternator assembly.
Position the alternator assembly against the engine and install the support bolt.
Install the adjusting strap mounting bolt.
Install the alternator belts and adjust to specification.
Tighten all the support bolts and nuts.
Connect all alternator terminals.
Connect the negative battery cable.
May 31, 2010 at 11:10 AM
