2002 Mazda Millenia the name of the parts i need to fix the
2002 MAZDA MILLENIA
HELPFIXIT
Engine Performance problem
2002 Mazda Millenia 6 cyl Automatic 111270 miles
frist is po400 generic EGR FLOW malfunction whats the name of the part i need here is the other p1522 variable resonance induction system solenoid #2 ciruit can someone tell me the name of the to parts i need to fix theses problem
Jul 30, 2008 at 8:34 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi helpfixit,
Thank you for the donation.
The generic code of P0400 means a EGR system malfunction whereas P1522 is not listed by Mazda under their error codes.
There is a possibility not any items are faulty, just might be some cleaning needed.
I would suggest checking/cleaning the EGR valves and passages first.
Jul 30, 2008 at 10:07 AM
HELPFIXIT
how do i clean egr values
Jul 30, 2008 at 10:17 AM
KHLOW2008
  • 41,814 POSTS
Hi helpfixit,
You need to remove the EGR valve and clean it by clearing the carbons that has accumulated in the valve passage. The passage in the manifold on which the EGR seats alsp needs to be cleared of carbon deposits. Some carb cleaner and a piece of flexible wire would do the job.
Jul 30, 2008 at 6:29 PM
