2001 Mazda Millenia replacing the thermostat
2001 MAZDA MILLENIA
100,000 MILES • 6 CYL • FWD • AUTOMATIC
JEREPERKINS
How do you replace the thermostat on a 2001 mazda millenia s? It is the supercharged version
Mar 13, 2010 at 5:10 AM
DAVE H
  • 13,384 POSTS
Removal & Installation
Disconnect the negative battery cable. Remove ignition coil. Drain the engine coolant. Remove water inlet pipe (1). On A/T models, disconnect oil cooler. On all models, remove thermostat housing (2). Remove thermostat (3).
To install, reverse removal procedure. Verify that the jiggle pin is aligned with the projection on the thermostat gasket as shown. Install the thermostat into the thermostat case, aligning the projection on the gasket to the thermostat case as shown.
Tighten thermostat housing bolts to specification. See TORQUE SPECIFICATIONS . Fill and bleed cooling system. See COOLING SYSTEM BLEEDING .
Mar 17, 2010 at 3:53 AM
