Will not start
130,000 MILES • 6 CYL • FWD • AUTOMATIC
BGZAMBONI
Car will turn over but will not start, has between 1/4 and 1/2 tank of gas. Have been putting fuel additive in on every fill up. Not sure where to start on fixing problem.
Jan 3, 2010 at 3:40 AM
  • 75,988 POSTS
Cranks and will not start.
Get a helper disconnect a spark plug wire or two and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 3, 2010 at 2:25 PM
RHWALTER
Had no power to start or lights and accessories. No power to anything at all.
Replaced battery and still nothing. What else could it be?
Aug 18, 2018 at 2:27 PM (Merged)
  • 75,988 POSTS
Inspect and test all the fusible links
2CP-ARCHIVES
  • 4,540 POSTS
mazda millenia does not start.if u give it a hard crank it shows signs of starting but it doesn't.what could be the problem?
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first.
KENNY718
having problem with starting my car and enegine light is on
Aug 18, 2018 at 2:28 PM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi kenny718,
Get a scan done to find out what is wrong.
SARAHMATT0808
Noises problem
1995 Mazda Millenia 6 cyl Automatic 160000 miles
When i first start my car it makes this loud clapping sound around the left side of the engine, after i drive the car it goes away or maybe not as loud to where i can here it...it seems as though it only does it when it is cold cranking up...what do u think the problem could be and should i be concerned?
BILLYMAC
  • 2,204 POSTS
hi sarah and matt. well this sounds like if you only hear it when you are cranking the engine, that it almost has to be a starter or flywheel prob, as far as concern yes it should be checked. could be the diff of a little money or a lot. good luck billymac
