1998 Mazda Millenia steering wheel adjustment
108,000 MILES • 6 CYL • FWD • AUTOMATIC
SSCHNEIDERMD
when I turn on the ignition, I'm unable to adjust the steering wheel with the electronic switch on the side of the steering column. Is there any way to adjust this manually. I've checked the fuse - it's ok. thanks
Nov 28, 2008 at 2:47 PM
LIVINIT4CHRIST
My wife has the same problem with hers. We have had it checked out and there is a control switch under the steering collum that goes bad. And as far as i have been able to tell there is no way to do it manually. You can either beat on it (which is what the mechanic suggested, ??) or replace it, which is what i would suggest if its too much of a bother for you. Hope that helps, good luck!
Mar 12, 2009 at 12:03 PM
