1997 Mazda Millenia Crankshaft Position Sensor *UPDATE*
14,500 MILES • 6 CYL • FWD • AUTOMATIC
BISHOPT77
My 97 Millenia is getting no spark.. Changed the distributor cap, the rotor, changed out all the spark plugs and spark plug wires.. Tested the Fuel pump and fuel filter.. Replaced the oil pressure switch.. Then, still no spark.. Someone explained that it's quite possibly a problem with the Crankshaft Position Sensor.. I can get one cheap, but my manual does not give a good explanation of where the sensor is located.. Any help on informing me of where the crankshaft position sensor is located would be greatly appreciated..
Apr 10, 2009 at 5:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Diagram is below illustrating location of sensor..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_436.jpg
Thanks for using 2CarPros.com!
Apr 10, 2009 at 7:08 AM
BISHOPT77
Thanks for the quick response!! I'm glad I found you guys..
Apr 10, 2009 at 8:11 AM
BISHOPT77
Is it possible to replace this myself without having to remove any drive belts??
Apr 14, 2009 at 11:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
No, not without removing drive belts..you cannot gain access to the sensor without removing belts.
Apr 15, 2009 at 3:32 AM
