1995 Mazda Millenia Engine doesn't accelerate
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
DSNRAJU
My 95 Mazda Millenia won't accelerate. It just starts. When I press the gas pedal. The rpm drops and engine makes dying sound. What could be the reasonable problem.
Jul 10, 2009 at 7:50 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would suggest that you start with a scan and look for codes that may indicate a faulty air flow sensor or throttle sensor, post any codes here, start here.
mark (mhpautos)
Jul 10, 2009 at 9:27 PM
DSNRAJU
[quote:5afff0fb3b="mhpautos"]Hi there,
mark (mhpautos)[/quote:5afff0fb3b]
Its in a garage. The mechanic says the Code reader doesn't tell anything. It says everything is fine. He says there may be a problem the computer is not detecting.
Jul 11, 2009 at 9:35 AM
  • 31,937 POSTS
Hi there,
The ECU reads input signals from all the sensors and if they are out of range then you get a fault code, if there is no code set, either the problem is with something to connected to the ECU or the ECU is faulty its self, i feel that this should be investigated, they can be bench tested to check for faults.
Mark (mhpautos)
Jul 11, 2009 at 11:29 AM
