1995 Mazda Millenia coil
1995 MAZDA MILLENIA
17,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROSOUNA
car was working but turned off after about 20 minutes i would wait about 10 min and it would start changed coil now it wont start at all what could it be?
Apr 29, 2010 at 7:40 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 30, 2010 at 2:19 AM
