1989 Mazda Millenia Slow accelleration
NICHOLESMITH70
  • 1989 MAZDA MILLENIA
1989 Mazda Millenia 6 cyl Automatic
When I put the car in drive it starts very slow. Even if I give it a lot of gas it has no pick up. When it switches gears it takes off and runs great until I slow down again. What do I need to check first?
Tuesday, June 1st, 2010 AT 11:27 AM
If the transmission is not slipping-do below:
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, June 4th, 2010 AT 11:24 PM
Related General Content
