Luke-warm start troubles
JOHNSMIATA
I have a 2000 Miata with 87000 miles. If it sits after running for less than 30 minutes, it starts up fine. If it sits for longer, but less than a few hours, it has trouble starting. The engine turns over fine, but will not fire. When it eventually does fire, it runs rough and smells of gas. It will run very rough for about 5 minutes and then instantly switch to running perfectly. The problem is intermittent. I've taken it to two mechanics, have had both oxygen sensors, the valve cover gasket, and all the belts replaced (with no effect).
Sep 29, 2007 at 4:04 PM
COLT45PHIL
  • 10 POSTS
The temp sensor are a large factor of engine setting and the temp sensor will effect starting. High resistance or low resistance from the temp sensor will cause this problem. Replace the temp sensor, clear the code. Problem solved. PCM's in any Mazda is pretty much bullet proof.
Mar 11, 2008 at 1:06 PM
