1990 Mazda Miata AC Water Leak
GREEN MACHINE
I have a 1990 Mazda Miata with 112000 miles on it. When I run the AC after a while the lower vents around the blower motor fill up with water and dumps onto the floor when I make turns. I think the drain might be clogged but can not locate it visually or in my Haynes manual. Does this car have a drain? If so where?
Dec 2, 2006 at 10:45 AM
COSMO
  • 347 POSTS
The drain hose comes off the evaporator right near the passengers left foot near the firewall/trans tunnel. It comes off the large black bow and goes into the floor. Try taking it off the black box and fishing some course wires through it to see if anything is blocking it.
Cosmo...Mazda Tech
Dec 4, 2006 at 1:51 PM
Suggested Repair
Remove the evaporator drain hose from the large black box near the passenger's left foot at the firewall and transmission tunnel, then fish coarse wire through the hose to clear any blockage.
Conversation Summary
The owner of a 1990 Mazda Miata reports that running the AC fills the lower vents around the blower with water that spills onto the floor during turns, and suspects a clogged drain that cannot be located. Expert Cosmo says the drain hose leaves the evaporator near the passenger's left foot by the firewall and transmission tunnel, coming off the large black box into the floor. He recommends removing the hose from the box and fishing coarse wire through it to check for a blockage.
