Rain water leaking inside under passenger side seat
MANHATT05
Four cylinder two wheel drive automatic 14,000 miles.
Hi
I just purchased this car used. I have noticed during the past rain storms that water is literally pooling under the passenger side seat. I do not have a garage to keep the car in. I understand there is some type of drainage system that runs into the car from the back of the convertible top. The drains must be plugged. I cannot however find where to locate these plugs. I do not have the money to go to Mazda. Do you know where to locate these? I have looked for a service manual on line and at auto parts stores but they tell me they are not made yet! Can you please help me?
Thank you in advance.
Brenda
Jun 28, 2008 at 12:50 PM
KHLOW2008
  • 41,812 POSTS
Hi Brenda,
You should try to verify the source of the leak before attempting to rectify it. It could be something else.
Remove the floor carpet, at least move them to enable you to see the floor bopard. Dry up the area and use a garden hose to spray on the car, starting from the lower part and going up till you notice any leaks.
Continue until you can find the source.
As to the drain hoses, for sun roofs they are located inside the front and rear pillars, rear going to the side fenders.
Jul 9, 2008 at 11:49 PM
JRZYSHELLEY
Hi Brenda,
Please do not follow the last user's response. I own a 2006 Miata and I know exactly what is going on with your car.
There is a defect in the 2006 and 2007's drainage system. Mazda has never done a recall on it. The defect causes the water to pool on the floors of the cab and in the spaces between the back of your seat to the trunk.
Mazda wants $1,000.00 to replace the old drainage system.
A friend of mine used a trombone cleaner to push the dirt out of the drains on either side and does this monthly. I tried it, but it did not work for me.
I am trying to see if I can order the new drain system which costs about $100.00 and find a mechanic who knows what they are doing to put it in. I will keep you posted.
Shelley
Jun 26, 2014 at 6:12 AM
YNGTOR
Shelley, were you able to find the part(s) and did this rectify the problem? I just bought an 2006 and was utterly unaware of this issue until the floors filled with water. I did know about the drain holes but they were open and seemed to not be the source of the trouble.
If replacing the system worked for you, can you tell me the parts?
Kevin
Jun 9, 2016 at 4:31 AM
MIATAJULIE
Please update what works. We all need to contact Miata to get a recall.
Jun 21, 2016 at 2:15 AM
