2006 Mazda Miata normal operating temp too low?
47,000 MILES • 4 CYL • 2WD • MANUAL
TVACCA
2006 miata coolant temp will not excede 175 degrees in normal driving after warmup. Dealer checked t-stat and said all OK. Seems to me that this is cooler than normal - 190 degrees would make more sense, Is this a problem and will it cause permanent damage running this cool? Thanks for the help
tv
Mar 24, 2010 at 4:04 PM
  • 75,988 POSTS
The thermostat controls the engine temperature could be stuck open or the coolant temperature sensor is out of calibration or the gauge itself
Mar 24, 2010 at 4:17 PM
