2001 Mazda Miata Rattling noise on cold startup
2001 MAZDA MIATA
26,000 MILES • 4 CYL • 2WD • MANUAL
KINGBRYANT
When the Miata is cold or semi-cold there is a very loud rattling noise coming from the engine area. We call it "the diesel" because the noise resembles a semi-trailer diesel engine noise. Otherwise the Miata runs fine performance-wise.
One dealer said it was something like a backpressure oil valve that they see in their CX-7s, the timing cover would have to be removed/might as well replace the timing belt while at it...and $1500 later it is fixed. I believe they are trying to generate revenue for unnecessary repairs.
Could something be loose in the engine or catalytic converter/exhaust system?
Mar 23, 2010 at 5:20 AM
2CARPRO JACK
  • 11,533 POSTS
That could very well be the oil pressure by-pass in the pump.It may have a weak spring or be sticky.If it is that they are correct that the timing belt and the front needs to come apart to access it.I would have something done about it, low/no oil pressure damages the engine internally and drastically shortens its life
Mar 23, 2010 at 5:59 AM
KINGBRYANT
The oil pressure gauge on the dashboard does not indicate no or low pressure, is the same as always. Is this a good indicator or could the oil pressure be low despite the gauge?
Mar 23, 2010 at 6:14 AM
2CARPRO JACK
  • 11,533 POSTS
Not necessarily low, just taking a second to build up in the engine.The incorrect oil filter can cause this problem as well.
Mar 23, 2010 at 10:10 AM
KINGBRYANT
It was the oil back pressure valve. Mazda had a TSB on this part in 2005. Valve replaced, engine runs much better with 2x acceleration, and no rattling/diesel noise on startup.
Jul 26, 2010 at 6:59 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear it is fixed
Jul 27, 2010 at 1:24 AM
