2001 Mazda Miata dies at operating temp.
2001 MAZDA MIATA
135,012 MILES • 4 CYL • FWD • MANUAL
MICORAZON26
i can drive my car about 2 miles then it looses power and dies the crank sensor had wires cut so replaced sensor , but still does it. it acts like it is running out of fuel when press the throttle it dies let it cool off for a minute and it cranks up with no problem. i thought it might be fuel filter cause it sat for a year with out being driven did not help so changed fuel pump still the same.
Jul 19, 2010 at 1:39 PM
EDWARD.S
  • 166 POSTS
Hi, First Thing I'd Check Is The Fuel In The Tank. You Stated The car was Sitting For a year . Was the Tank Checked For Stale Gas And Water? Was Tank And Lines Cleaned out? Take A Gas sample. And Have The computer scanned For Codes. Write Them Down If any
Hope This Helps you,
Good Luck
Edward S.
Jul 19, 2010 at 2:08 PM
