2000 Mazda Miata will not start
28,000 MILES • 4 CYL • 2WD • MANUAL
MOZE
My Miata was working fine when I last used it. I haven't driven it for a month and a half. I went yo start it and it would not start. The starter and motor turn over, but it won't start. It has gas, battery is charged so I'm at an end
Oct 3, 2010 at 12:38 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 3, 2010 at 12:40 PM
