1999 Mazda Miata Not starting
98,000 MILES • 4 CYL • 2WD • MANUAL
WSCHLAGEL
While working on my car's idle adjustment, I acidentally dropped a tool on the diagnostic port in the engine compartment, and the car stoppped running immediately. The car now turns over, but won't start. I don't get any indicator lights (check engine, etc), and can't connect to the ECM to check codes. I checked the EGI relay and it appears OK. Have I damaged the ECM?
Nov 3, 2008 at 7:55 AM
JAMES W.
  • 2,394 POSTS
If it didn't blow the ECM fuse, I would have to say your computer went "belly up".
Nov 3, 2008 at 3:27 PM
