1997 Mazda Miata
MKHULSEY
  • 1997 MAZDA MIATA
  • 4 CYL
  • MANUAL
  • 80,000 MILES
Problem started when the engine seemed to be misfiring. We replaced the plugs and plug wires and fuel filter. The car ran great for about 60 miles, then it stalled at a red light. After that the engine would crank but would go dead. After about 10 minutes, the car would crank and idle and seemed to be fine. About 2-3 miles down the road, it stalled again and had to be towed. I let it idle in the driveway for about 30 minutes and everything seemed to run okay, so I drove it about 3-4 miles with no problems. After that we accelerated in 2nd gear up to about 5500 RPMs and the engine stalled. The check engine light does not come on. The engine will start but immediately goes dead. After 5-10 minutes to cool off, we were able to drive it back home with no problems.
What problem does the car seem to have with this information?
Wednesday, June 25th, 2008 AT 2:11 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
The other possibility is if it only happens on idle and decelleration, the idle air control valve may be defective, this is bolted to the side of the throttle body.
Wednesday, June 25th, 2008 AT 3:57 PM
