1995 Mazda Miata Car will not run
EASTRIDGE11
Engine Mechanical problem
1995 Mazda Miata 4 cyl Two Wheel Drive Manual 139K miles
Car will not start. It starts only if I use starter fluid but will not continue to run. Seems fuel is not getting to where it needs to go. I do not know where the fuel pump, or filter are located.
Nov 9, 2008 at 7:34 AM
  • 75,988 POSTS
Check the fuel pressure, the fuel pump is in the fuel tank-and injections pulses-
Nov 9, 2008 at 7:40 AM
