1994 Mazda Miata white or light grey smoke on take off
102,000 MILES • 4 CYL • FWD • AUTOMATIC
BLERMA
My wifes Miata throws out a puff of white or grey smoke at initial take off from a stop. This occurs after warm up but does not occur all the time. After cleaning the MAS, Throttle valve and replacing the o2 sensor, Spark plugs & wires, and air cleaner, the problem went away for approximately one month. Now its back but this time is puffing more often. Also when this occurs, the engine pings. This only happens on take off or first gear. After it shifts into second, everything is fine.
Oct 9, 2008 at 8:44 AM
JAMES W.
  • 2,394 POSTS
Are you losing coolant over a period of time?
At an idle, after engine warm up, do you see bubbles coming up in the coolant reservoir?
What, roughly, is your oil consumption?
When you installed the new plugs, did any or all of them look carboned up or oily? This info will help narrow your problem down. At this point I'm thinking head gasket, cracked head or the motor is just getting tired. Please advise.
Oct 9, 2008 at 9:36 AM
BLERMA
Doesn't seem to be losing coolant between services. Is possibly less than half a quart low between oil changes, (3000 miles). Only #4 spark plug had slight carbon buid up.
Oct 10, 2008 at 1:47 AM
JAMES W.
  • 2,394 POSTS
I would run a compression test on all cylinders and compare the results. You may find #4 cylinder is lower than the rest. Please advise.
Oct 10, 2008 at 6:15 AM
BLERMA
I did compression test with the following results: #1 190 psi, #2 185, #3 185, #4 190. All cylinders maintained pressure however #4 did show signs of oil in chamber. I cleaned MAS sensor and trottle body again and this seemed to improve condition. Drove around neighborhood and car didn't smoke at all. Took car on freeway and ran geat until I came to a stop after exiting. Smoke returned but seemed less as I continued to drive in residential area. Got back onto freeway with same results upon exiting. Could this have something to do with air fuel mixture or pressure?
Oct 14, 2008 at 8:18 AM
JAMES W.
  • 2,394 POSTS
Compresson looks good, even exceptional for over 100K. Is your EGR valve and air pump working? If not, it won't affect the running of your motor but, it should recirculate some of the smokey exhaust and burn it up on deceleration. Just a thought.
Oct 14, 2008 at 10:14 AM
BLERMA
Cleaned EGR, doesn't have air pump. Tested EGR with vacuum tester and checks ok. Took it by a shop to get mechanics opinion. He thinks it's valve seals. He says the car smokes during warm up and very little when driving. I don't notice while driving and don't see smoke during warm up. If it was valve seals wouldn't it miss or foul plugs? And wouldn't it smoke and ping at every stop?
Oct 17, 2008 at 12:25 PM
JAMES W.
  • 2,394 POSTS
Bad valve seals usually won't foul plugs unless they're "really" bad. It's normally low compression that fouls plugs. Try running it around the block a few times so it's good and warm. Shut it off and let it set for 20 to 30 minuetes and restart it. If you get a puff of smoke when you start it. It could be seals.
Oct 27, 2008 at 7:14 PM
