My wifes Miata throws out a puff of white or grey smoke at initial take off from a stop. This occurs after warm up but does not occur all the time. After cleaning the MAS, Throttle valve and replacing the o2 sensor, Spark plugs & wires, and air cleaner, the problem went away for approximately one month. Now its back but this time is puffing more often. Also when this occurs, the engine pings. This only happens on take off or first gear. After it shifts into second, everything is fine.
Oct 9, 2008 at 8:44 AM
