1994 Mazda Miata OVERHEATING
194,000 MILES • 4 CYL • 2WD • MANUAL
OVERHEAT IN OHIO
Losing coolant and overheating. Changed thermostat and still losing coolant and overheating. Don't know if this is related to but in the summer when the a.c was on the passenger side floor would get real wet.
Nov 24, 2008 at 7:40 AM
  • 75,988 POSTS
in the summer when the a.c was on the passenger side floor would get real wet. The drain tube could be clogged-up
For the overheating get it block and pressure tested to find out-
Nov 24, 2008 at 7:50 AM
NADIDEG1
[quote:1641606cbc="overheat in ohio"]Engine Cooling problem
1994 Mazda Miata 4 cyl Two Wheel Drive Manual 194000 miles
Losing coolant and overheating. Changed thermostat and still losing coolant and overheating. Don't know if this is related to but in the summer when the a.c was on the passenger side floor would get real wet.[/quote:1641606cbc]
I have the same issue. I always keep a big jug of coolant in the trunk and refill as necessary. I'm hoping the pros will answer this question for my sake too.
Dec 12, 2009 at 1:06 PM
  • 75,988 POSTS
I have the same issue. I always keep a big jug of coolant in the trunk and refill as necessary. If you're not physically leaking anywhere-then its burning in the cylinders due to blown head gasket, cracked head or block,intake manifold leak or its going into the crankcase-check oil level/condition. Overall get it block and pressure tested to find out where its leaking
Dec 12, 2009 at 2:40 PM
