1993 Mazda Miata Starts but stops very quickly
225,000 MILES • 4 CYL • 2WD • MANUAL
DCUNDIFF
After repalcing most every component in the spark train I now have solid spark and the engine fires up with the aid of starter fuild everytime but dies. wher would you suggest I start my efforts and what items to check. It is not timed well since I replaced the cam position sensor during my quest for fire.
Nov 30, 2009 at 12:29 PM
  • 75,988 POSTS
You got spark now check the fuel pressure with a fuel pressure gauge. See specs below
FUEL PUMP PRESSURE
Maximum 64 - 85 psi (441 - 589 kPa)
Hold over 50 psi (343 kPa) after 5 min.
FUEL SYSTEM PRESSURE (REGULATED)
With 18 - 21 inHg Vacuum To Regulator 31 - 38 psi (216 - 265 kPa)
With No Vacuum To Regulator 38 - 46 psi (265 - 314 kPa)
FUEL SYSTEM HOLD PRESSURE 21 psi (147 kPa) min.
Nov 30, 2009 at 1:02 PM
