1992 Mazda Miata upper raideator hose
1992 MAZDA MIATA
120,000 MILES • 4 CYL • 2WD • MANUAL
JASONSCOTT619
after the car has been parked over night the upper hose on the raideator is flat like it has sucktion & if i take the raideator cap off air get`s sucked in.. do you have any ideas ?
thank you for your time
Jun 6, 2009 at 10:35 AM
  • 31,937 POSTS
Hi there,
The return valve in the radiator cap is faulty and this is causing a vacuum to build up in the cooling system as it cools causing the hose to collapse, replace the faulty cap.
mark (mhpautos)
Jun 6, 2009 at 11:46 AM
