1991 Mazda Miata no power to ignition
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
DARTWISER
drove it yesterday, all fine.
today, no power to ignition, won't shift out of park,
steering wheel does NOT lock up.
could it be dead battery oe something else?
Jul 14, 2010 at 10:34 AM
  • 75,988 POSTS
If this no power to the ignition-when you turn key to run and the lites that you normally see is not there-Check and test all the fusible links, miniature fuses if all okay -test the ignition switch
Jul 14, 2010 at 11:23 AM
